Does any S20+ work on Verizon after flash?
  • Start date Start date
A
Android Central Question
I'm looking to replace my factory unlocked S9 with a used S20+. I have an almost 10 year old GUDP (Gradfauthered Unlimited Data Plan) from Verizon. Because my S9 is factory unlocked I can use my phone hotspot without it being blocked. I know that if I buy an factory unlocked S20+ this will work the same way. I wanted to know what might be the tradeoffs (if any) of someone's unlocked carrier phone (from AT&T, T Mobile, Boost, etc.) and then just flashed it to the phone I wanted.
Questions:
1. Is the phone hardware in the S20+ identical regardless of if you buy an unlocked phone from Samsung or a carrier phone from any of the carriers?
2. If there is no difference in hardware, is there any reason not to just buy the cheapest S20+ you can find and flash it to the firmware you want?
3. I want to be sure my Hotspot is not blocked by Verizon firmware. If I flash a Verizon phone to a Factory Unlocked firmware is there any reason the phone would know it was orginally a Verizon phone and block the hotspot from working.
4. Has anyone tried doing this. I'm especially curious to hear from any of you who may have a Verizon GUDP who use there hotspot after flashing a verizon (or other carriers) phone.
1. They are identical for all
2. Yeah if you like to find the cheapest, then flash will be ok.
3.yes Verizon to factory unlock you can do
4. I have done flashing between all carriers and unlocked no issues .
I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
https://forums.androidcentral.com/showthread.php?t=409154
Adekanmbi
