Does gear 2 neo supports note 4?? need help
jeno27
293
going to buy gear 2 neo..does note 4 support gear. ..2 does anyone using..
It should work with it, I have the gear S And the gear 1 running Tizen and they both work with my note 4.....
Galaxy Note 4
Galaxy Tab Pro 8.4
Galaxy Tab 2
Galaxy Gear S/ Gear 1 Tizen
Galaxy Circle/ Gear Level speaker
I'm using the Gear 2 with my Note 4. It works great. The only real difference between the Neo and Gear 2 is the sound and call ability, so you should be fine.
Nehasingh12
