Does note 2 work with a charging pad?
ansa82
1,899
116
63
2 questions actually
1. Can I use a charging pad
2. Is there an extended battery?
Thank you!
sent from my Galaxy note 2
Extended battery..Yes Charging pad I think depends on what carrier you have.I know you can't with Verizon.
Yes, you can use a charging pad, but you would have to physically hack the phone to expose the contacts
Sent from my BN NookHD+ using Tapatalk 2
Thanks! Do you know if the extended battery is by samsung? Or does it take a generic? And does it make the back of the device bigger? Need a new back?
sent from my Galaxy Note 2
Samsung doesn't make an extended battery, so it is third party. Any extended battery that substantially increases battery life would require a new back
Sent from my Verizon Samsung Galaxy Note II
kingteekay
