Does the market not work with fresh?
Market should work with every ROM
Try pulling the battery and reboot, I've had that problem before.
If that doesn't work, reflash the ROM
i am using fresh until cyanogen comes out, and i have been able to use the market without a problem, have been using fresh since the 29th
I haven't had any trouble with either fresh 0.3 or 0.5.3.... market has worked with both no problems.
Make sure you....
-wipe the required stuff before flashing the Rom
-after flashing and boot up, be sure to sign into your gmail in that first setup screen, that way when you go to the market, it will already recognise you.
I can get into the market, but when I try to download apps it just hangs on the downloading page.
I would call sprint tech support but honestly I'd get more done dropping a cinder block on my head
Don't do that, there's nothing they can do. Try downloading one over wifi then with it off a couple times
I got it fixed. I took off gtalk and that seemed to mess up the market, reinstalled and now its working
piikea
