Does this replacement LG G4 back cover(battery door) look genuine to you?
Pretty much. Feel it. Any rough edges? The real one shouldn't have any. (I assume those white blotches in the first picture are just glare from a light or the flash.)
I haven't actually ordered it yet. I'm only a little concerned because one of the previous buyers left a feedback for the seller and said NFC didnt' work.
Some of the covers are not perfect or have slightly different curves, and the contacts don't connect between the cover and the phone. A piece of tape under the contacts (to raise them up just a bit) will fix that (unless of course, the NFC coil is bad). I have 2 leather covers and they are just a bit different if you put them next to each other off of the phone. One required the tape fix.
sanajy210
