Does using Android Pay, Apple Pay, or Samsung Pay cause shorter battery lifer?
KiwiCoalBattery
203
I currently have NFC off at all times...
You do not need nfc on to use Samsung pay,, the other 2 you do.
Note 5 is DOPE
wait a sec, why doesn't the Samsung Pay need NFC on?
Because its advantage is that while it will work with Near Field Communication (NFC), it primarily uses Magnetic Secure Transmission (MST), which simulates a card swipe and transmits the data contained in the magnetic strip on your card.
Apple and Android pay rely on NFC only.
