double press power button
ep1
87
when I double press power button for the camera it wont come on? I have soft case on there.
if I take it off I can get it to come that won't work is there something I'm missing
So without the case it works? But with the case it will not work?
It sounds like your case is impeding the key press. If so, you need a new case and there isn't anything the rest of us can do to help....
Yeah sounds like the case may be pressing on the button slightly. I would try to maybe stretch it out a little.
The case may also add too much of a bounce. I've found that I can't have too much time between the two presses if I want my phone to recognize it as a double-press. The bounce and release may add in a slight delay.
toolpunk
