N nitro2k1 Active member Oct 23, 2017 39 0 0 Dec 8, 2017 #1 My double tap and lift to wake feature on the Pixel 2 is very inconsistent. I noticed that double tap to wake doesn't work at all while plugged in. Is this as designed or is it working on your device? Thanks for the replies.
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,583 10,994 113 Dec 8, 2017 #2 Works on my 2 XL. Are you using the original charger, or a 3rd party one? Does it still happen in Safe Mode? https://support.google.com/pixelphone/answer/2852139?hl=en
KillerQ Well-known member Feb 23, 2011 1,092 24 38 Dec 8, 2017 #3 +1 on 3rd party chargers making the screen wonky.
cbreze Well-known member May 30, 2011 2,887 91 48 Dec 9, 2017 #4 Mine works fine plugged in on P2, non XL.
