Double tap to zoom
TheLastPanda
185
I think I used to be able to double tap to zoom. For example I could double tap a desktop version of a Web page to zoom in to the text or photo. Also, double tap on a photo in the gallery app to zoom in. I can't seem to do this anymore.
I know about the triple tap zoom feature but that's not what I'm talking about.
How do I re-enable double tap zoom feature?
What's a triple tap zoom feature?
I use the chrome browse on tlmy note 5 and double tap zooms In.
Posted via Note 5 AT&T
Not sure that it can be enabled/disabled as an option... also try double tap (hold on 2nd tap) then drag. Down zooms in, up zooms out.
Do you use package disabler?
Thanks, I never knew the hold on 2nd tap.
Double tap works on both gallery and Web pages for me. Maybe you accidently disabled a process.
I have package disabler but have nothing disabled through it. I now disable through the phone's settings.
I tried holding the second tap and dragging but it doesn't work.
Zooming by double tapping doesn't work anywhere anymore including stock Samsung apps
Just figured it out. The triple tap zoom feature has to be turned off for double tap zoom to work
