Droid DNA charger problems
spartan1500
7
So im having a problem with my Droid dna when I put it on the charger it won't charge it has to be in a perfect position
For it to charge and that's with all the cords I have tried. Anyone else having this problem?
Sent from my HTC6435LVW using Android Central Forums
You are using the cord provided in the box, and your phone was new? I'm not certain but it sounds like you need to have the micro-usb set just so to make contact.
I've had this on phone 1-2 yrs old that had worn out the usb connection over time but a new phone should not have this issue, Take it back to vZ and have them take a look / exchange.
I took it there Thursday and they said it was only a tight fit but I brought it back and the same thing and I called the technical support and they said that it should not be doing it and the employee should have exchanged it.
nemismom
