Droid DNA update
updated, still 4.1.1. and sense 4+
A small update - prep update - some apps updated, then, check for new software and it is downloading now!
The update is only 14mb, probably some pre-update that gets the phone ready for Sense?
After the 14MB update is finished, check for updates again. You'll see a massive 564.9 MB update!
Go back and check for update again. It will download the 4.2.2 sense 5 update. Doing it right now.
I did the 14MB update and immediately checked after the update and now the half gig update is there. It is rolling out right now. I will see if I can attach a screenshot from my phone.
When you all are downloading the huge update, is it giving you a percentage of how far along it is or just a scrolling blue line? I want to make sure the courthouse Wifi is not blocking the download.
I had both the percentage and scrolling blue line.
I'm showing the blue line but when I tap it, it shows both the blue line and percentage.
Annnnd it bricked my phone. I got a red triangle and exclamation mark after the update downloaded.
I am glad there has been a admission that the voice mail notification was broken and will be fixed! That was my big pet peeve
You guys are lucky. My download failed and now I can't get the phone to check for the update again. I restarted the phone twice and no luck.
were you rooted
- - - Updated - - -
Try again that is how I got it to come back
download completed, then, it took a little while before I got prompted to install now or later. It is updating now.
rosannejoy555
