Droid Incredible 2 stuck on HTC screen. Help?
Cremacious
4
I've been unable to find any help via Google on how to fix my problem.
I was installing a ROM through Rom Manager when it got stuck on the HTC screen. I had to pull the battery out. I'm able to get into the boot by holding down the volume down button and power, but selecting Recovery only sends to me the HTC screen to get stuck again. I used an app called Nandroid to create a backup on my SD card earlier.
I admit, I'm fairly new to all this (probably why this happened in the first place =/) so if you can explain how to fix my problem in layman's terms that would be great.
By the way, when I'm in the boot menu it says S-Off. I figured saying this now would skip a question later on.
And when I first get into the boot menu is (very) briefly says something about no finding pg32diag.zip or pg32img.zip. It comes up for a split second and I don't have time to read it.
RayAndrews
