droid incredible battery problems
Droid User11
71
I have had my droid incredbile for about 2 weeks now and the battery life has be average. Today at 4pm the battery was at 80% and after a few hours of sitting on standby it dropped to 20%. I know it has to do with it syncing something all the time but i dont know what to do. Please help
There are many threads about batteries, extended batteries and the like. I'm not looking to say "just search," but you will find a ton of information on this subject in this forum.
umm. it says a lot of cell stand by and android system. I use task manager and after like 10 minutes of not using the phone all the applications are open i dont get it
That's just how Android seems to run things. I would stay away from the task manager if I were you. It really doesn't do anything useful at all. Is your phone staying awake all the time? (To check, go to Settings->About phone->Battery and compare the Up time reading to Awake time. The Up one should be higher. If they're the same or very close to it, an application is keeping your phone awake).
Ishimwe
