Droid MAXX: car issues..phone works but not media
Adam21221
6
Ever since the update... My Bluetooth works for making phone calls.. But not for playing my music... Car says.. No media device detected.. It's a 2012 sonata... It all worked fine before the update.... I've tried all I know to do... Any help????
Re: car issues..phone works but not media
Go into the Bluetooth settings and bake sure it's set for phone and media on your phone
Sent from my XT1080 using Tapatalk
Did you unpair and then pair?
Sent from my Nexus 7 using AC Forums mobile app
Sure did... Even deleted phone from car.. And car from phone .. still nothing
I also noticed... It won't even play music out of the speakers.. Have to put in ear buds to hear music
Try resetting phone if doesn't work then do factory reset. I had same problem on Razer with switch to ICS. Reset worked
You wouldn't happen to have the Text Plus app installed, do you?
trecth
