Droid RAZR M KitKat Issues and Problems
My sister-in-law has a Razr M, and almost since she got it she's had some lag issues. But after updating to KitKat it got way, way worse- now it doesn't like to power-on. Like you push the power button and it turns on, but then it shuts right back off, and you have to fight with it until it finially stays on. And the lag didn't improve whatsoever.
Any suggestions for fixing these problems? Will a future update fix these issues?
Your best is a reboot and if it does not work, a factory reset should help. When I updated, I factory reset and lag and any issues went away. I also turned off phone animations in developer settings to make things speed up a bit.
I loaded the update --4.4, kit kat and now my Bluetooth ear piece is not working. The phone never finds it. I tried 2 different ones and no luck. Anyone else having this issue?
I still recommend a factory reset. Majority of users who do one, it helps clear a lot of issues.
Thanks for the help!
easeasea
