DROID TURBO: Is there a way to get a different notification sound for SMS and MMS?
Snareman
2,384
54
48
I thought I had the option for different sounds for SMS and MMS a few phones ago, but can't seem to do it now. I'm using ChompSMS btw. Does anyone know if its possible to do?
Re: Is there a way to get a different notification sound for SMS and MMS?
The app you are using has to have the option to change the sound in the settings or it will just use the system default sound. I use Message+ and it allows me to change the sound.
Thanks. i'll look into that.
Maybe I read the original post incorrectly but I think he's asking if he can use different sounds to differentiate MMS from SMS. I'm not sure if any application does this but I'm just throwing this out there in case someone knows.
Yes, you are correct. Thanks. I read his reply apparently as fast as he read my initial post. Yes, I want one sound for SMS and one sound for MMS like I used to have.
Ah sorry for misreading it. Even then I would say the settings would have to be in an app. Never thought to do that because I get lot of group texts that come in via MMS so it really doesn't matter to me.
dkpiper
