droid x 2.2.1 install fails
I take it back...it failed and I'm still unable to go from .340 to .596. Getting to .340 is working, though.
swype.apk anyone?
Ok found the reason and the fix. Thanks to the forums out there I was able to find the info.
Hope this helps someone else out
This was a tremendous help, thanks! I didn't know about pressing the search button.
For me, its swype.apk that's missing. I don't recall messing with it, but I did stop using the version that came with the phone and started using more recent versions. Maybe one of the swype upgrades got me.
Anyway, does anyone have the stock swype.apk they can hook me up with?
TIA,
Jack
My friend is having similar problems, i think it might be a modified biuld prop file, can anyone post the stock?
for me it was droid x overclocker is what modified my build.prop file since i messed in the extras and changed things, durring the install of the new update hit search and you can see where it fails. Thats how i found out it was the /cache/blur_version.2.3.15.MB810..... failed authorization
All you need it a stock droid x 2.3.15 build prop, then paste it to the system folder using root explorer or simular file viewer. I restarted the phone, then clicked for the update search and let it do its thing, finally it installed all the way
Attached below is the stock froyo droid x build prop
thanks for the link
MichaelCrusan
