Droid X default wallpaper
Can I email the ogg file to my phone or is that not possible?
I'm having trouble getting the ringtone I want onto my Incredible.
+1 on the Inc here, I have been wanting those DRROOOOOIIIDD sounds on my phone (don't know why they're not there since this is a VZW thing, but anyway)... i don't see the path mentioned above when the card is mounted to my PC like a disc drive. Is this different for the Inc?
Anyone posting the sounds to another site (MU for example)? I can't access 4shared
Thanks in advance!
for the Inc, i found the ringtones in /system/audio/ringtones.... Using Astro, i sill can't move or copy the files to that location, or extract to that location. But i guess i can just assign them as ringtones as any other media file huh?
Can someone tell me how to get the DROOOIDD sound as the boot-up audio on the Inc?
Greetings,
New here.....porting from a Pre (PreCentral.com) over to an EVO (this site). How do I install the X keyboard file?.....yes I did a search!!
IGO
OK, these are the ringtones, are there any new notification sounds? I'm using Droid Labs now, but it's a smidge too long (twss). Other than that, DL'd the tones and papers, and can we say awesomeness??!?!
Thanks a million!
thanks flipfone, that did it. the path exists in the phone storage by default. but creating the same path on the card did make them appear in the phones ringtones selection.
Is the wallpaper with the eye a live wallpaper or static? Like to put it on my incredible. Either way, I'd like to download that. Anyone make it available yet?
On the incredible, just create 2 new folders on the SD card called Ringtones and Notifications. Dump the sounds there, then go to the notifications sounds list. They'll be there. Not sure about the boot up sound though.
I can't figure out how to set the ogg files. They are on my sdcard under downloads, but I do not see a file labeled media/audio/ringtones. I have found the file under stem, but they are mp3 files and it will not let me dump the ogg files there. I am on an Incredible, any suggestions?
If you open the ogg files through astro file manager you can play them and set as ringtone and such. This is how I did it anyway.
kathynickerbutt
