I bought all my accessories at my local verizon store...received the 20% discount. Really helped me out since I bought the Dock, screen protectors, HDMI cable and a case.
They should have given you 25% off since you bought 3 accessories...
I use a program called "droid settings profiler" which allows me to set up my profiles just like on my old blackberry. I really missed that feature until I got the app. It's a couple bucks I think, but well worth it for me so I can set up a night profile so that only the phone ringer will wake me, but no messaging or other alerts will wake me up. I have it with the default of 3 profiles for normal, vibrate, and night and that seems to work out great. You can even set up each profile to have wifi or bluetooth on or off for that particular profile. It's a handy app coming from a blackberry last year to a Droid. It works just as well on my new X.
I like mine, but I have noticed that it is a bit difficult to pull the device off sometimes. I don't think the connectors are perfectly aligned.
Also I think it would have been nice if it had a 3.5mm stereo out jack.
-n8
I like the dock. Main reason i got it was to put it by my bed and use it as a alarm. The only problem with that is I have to manualoly put phone on silent and turn off notifications. On the storm 2, it had a bedside mode. I could set it to turn the radio off when plugged in and every night when i put it in the dock, it automatically went to bedside mode and when i took it off the dock in the morning the phone came out of sleep mode. I'm going to miss that feature.
How do i make my DX into alarmclock. When i used to plug my storm in, a clock wld appear on a screen. When i plug my DX it doesn't do that.
I like the dock a lot. The biggest gripe I have with it is the fact the left side of it is soo loose! I'm afriad if it ever gets knocked over, it'll take the micro usb, and mini(?) hdmi ports with it. Other than that, it's quality stuff.
I got for 35% =)
