Dropped my Galaxy S4 in the toilet, won't charge?
Re: Dropped my s4 in the toilet, won't charge?
.1 in screen size yes. The phone itself is quite a bit bigger. I'm a power user for sure and a one hander. Ummm with my phone I mean :)
Anyway three of the four of us came to Samsung from the z10 and I thought that was big compared to years dog legacy BB devices. S4 is max for me for me.
Samsung Galaxy S4 And 4.4.2 Switched from Z10 July 26.2014
Woah woah woah.
Well. If the S4's size works for you, then that's great. But don't forget that the next phones in the line will get nothing but bigger.
Guts I need help and sorry to interrupt but I'm having charger issues with my s4. It happened when I changed my USB cable from a connector which it is 5V and A1. Idk if it's because of amp but but I need tips. Only started and when I replace my original usb to my older usb but the connector is still ok. Is it ok to use it? When I used my phone the battery still keeps going down whole charging. I hope you can respond. I need help
Are you stuck with this charger? I'd advice you but a new, Samsung branded one with the original power brick.
I drop my galaxy note 4 phone in the snow this morning, I have taken out the batt and SIM card, what do I need to put in rice,( the batt,or the whole phone) , is it a raw rice or cooked?
Please,I need help.
Thanks.
You say now he should have a waterproof case but you don't think it will happen to you.
Correction i Had a Lifeproof Case on my phone; And no that did not help anything!!! I still had to bring the stupid thing in~
I realize this post was written years ago but I hope you see this and reply..I had my galaxy note 4 in my back pocket and went to use the bathroom and kerplunk!! Obv I'd forgotten my phone was on my pocket but when I heard sumthn fall in the toilet I immediately turned around and grabbed it out, took the battery out and dried it off. I'd never read anything about dropping a phone in water so I didn't know I shouldn't turn it on until after it'd been in rice s & I was so worried that it'd be messed up I tried to turn it on which it did but when I got home and plugged in the charger I noticed it wouldn't charge and put it in rice for almost 2 days but it didn't do any good..So I'm really wanting to know ifSamsung told u what they had 2 do to fix the water damage so I can try to do the fix myself bc I don't even have $80 to pay Samsung to fix it, plus it's obv not under warranty either. Plz respond if you see this bc I'm distraught without my phone!!! Thanks!! Oh and btw I was wondering why people kept referring to you as "he" bc I noticed you said you had ur phone in ur bag which made me realize you're more than likely female. People just love any opportunity to talk sh:t
r3dpuk3
