dropped z3 in oil.. how do I get oil out of speakers?
Kleptolol
Title says it all. My z3 was completely submerged in oil and luckily it came out fine, except the oil seems to be staying in the speakers and muffling the sound. Any way I can remove the oil safely?
Hey this is about 3 years late but I would recommend getting some compressed air, either in a can or an air compressor and and some "Electronic Cleaner" for cars. Go to the parts store and get a can of CRC Electronic Cleaner, its easy on electronic parts and doesnt harm most plastics. Spray into you speakers and flood out most of the oil and then spray the air into the speakers without using too much pressure. 91% rubbing alcohol works also but can damage plastic. Hope this helps someone else.
mldevgg
