Ebay Battery for Incredible
herbmmm
174
I've found some batteries on Ebay for the incredible but the size is 3.7 V 1800 mAh will this fit without getting replacement back?
I am not sure about that. Have you tried Amazon? I got new standard sized ones there for $9.00 each. I think the 1750's can use the normal back so maybe you'd get lucky with the 1800's.
Yes. I got mine from HTC Express. Better deal with them. Check it out. I have two batteries and wall charger. Didn't need cover. Fits original
sent from my Incredible using tapatalk
+1 on htcexpress.com. I got a really great deal on two 1800 batteries and a wall charger. I ended up selling the other 1800 battery......don't need it with CM7 and Chad's latest kernel.
I bought 2 1900's plus wall charger from Amazon. They just fit under the original cover and, after a couple weeks of use I am noticing improved battery life. They were around $20.00.
Yup, me too. They are made by Anker. On CM7 with Juice Defender and with moderate use, after 36 hours my phone sits at 40%. Of course millage will very. But even if I can get a full day with heavy use, these are well worth it.
I might pick me up some of those 1900's I've been trying to find something that will help me get through the day.
JohnD8851
