Been playing with it all morning and got nothing. I have edge lighting on, manage notifications is set to all apps just to see what it does and nothing.
Where is the popup option for Gmail? I've looked and looked. No such option in gmail settings>notifications so where is popup option?how do i set all my notifications to sound and pop up? i did it for just gmail and still dont get edge lighting.
Settings/Notifications/See All/GMail. There you need to set the MAIL notification style options for your account as SOUND AND POP-UP. If it's set to just Sound (default) it will not trigger edge lighting.
Mine does not work even with all the suggestions above.
Do any other notifications work? Are you getting Gmail notifications, just not edge ones with that app? If so, tap and hold the notification when you get one, press Details. Is everything there for Mail set to pop up?
