Edge panel customization is gone?
romjae
23
I just went to change my settings for the edge panels and noticed that the customization options are gone.
The option to change transparency, which side or the location of the tab on the screen all seem to be missing. Is this a nougat thing? Or is there something wrong with my edge?
Ummm, mine were still there until last week. Nougat update, T-Mobile version. Have you looked through all the settings? I also changed the settings on the S8 and they're still there, so don't see why they'd be gone on the S7E.
Bring up the panel, click the settings button, then in top left corner of edge panel screen click the 3dot menu and then handle settings. It's been moved in nougat.
Thanks Jamaica. I need to change the color settings on screen I guess because I had no idea there was even a button in that corner.
Oh, yeah, a lot of themes do that, unfortunately haha especially after Nougat made everything light.
on s8 Galaxy 11/29/19 software updates 11/19/19 At first Edge screen was automatically changing sides then I suddenly had NO edge screen and NO 3 dot menu anywhere on edge screen. OS PIE. After doing app updates (not system) when clearing cache, i found that biometrics app shuts down/fails. After going through Samsung Community, found a lot of similar issues after updates..but no solutions.
Please, any help out there.
ZOMBIE
