Edge panel issue
evohicks
1,641
212
63
Just noticed this when selecting the quick tools edge panel. It always says 'preparing'
Does anyone else do this?
I never tried it under Android Oreo so cant comment if it's just a One UI/Android Pie issue.
I just tried mine ,it works
can you go Into ruler or any of the others?
No, it won't open any of them. I have found someone with the same issue on XDA forums but short of a Factory reset, no joy.
Yeah I've done all that, from closing the app to wiping cache, it must be some setting somewhere or app.
I probably won't use that edge panel much anyway so I don't think I'll be doing a FR anytime soon unless other things start to go weird, its just the fact that it's not working that's all.
I hear you ..if I find anything let you know.
I'm having issue with button for silent only goes vibrate not silent .
I just enabled the quick tools edge panel; it only said 'preparing'at the initial setup.
With volume control with buttons it go to vibrate not silent
I just checked mine Mustang and it works - if you're talking about the button in the settings pull-down at the top. I tap it once and it goes to "Vibrate" - I tap it again, it goes to "Silent" - I tap it a third time and it comes back to "Sound"! (that's with the new AT&T Pie update as well)
No I'm talking about the volume button control wont go into silent just vibrate , toggle works in notifications panel
Was it like this on oreo Att?
I truly don't remember if any of my phones ever went silent from the volume button, now that you ask. If I thought that my Galaxy S7 Active might still have any semblance of a charge left in it, I'd pull it out of the box and try it. That was prior to my Note 8 however, so it's been boxed for a very long time and I think it was still running Nougat when I shut it down.
I see.. on tmobile and unlocked firmware it did .
I haven't had this issue occur with mine. I'm currently on the standard Oreo with my Sprint Note 9. Have you checked for any updates with your phone 4 the system possibly for apps as well? There are like system apps and also the Google Play apps. Have you had any other issues with it besides the edge panel.
Never had any issues with the phone or apps and not sure it worked on Oreo because I never tried it. Always keeping Samsung apps, Google apps up to date, but still I'm not that bothered I just wanted to see if others had an issue with this as I saw another post on XDA with the same issue.
https://forum.xda-developers.com/galaxy-note-9/help/quick-tools-compass-t3884192#post78816216
dkpiper
