"elvislogs" folder in internal storage?
Re: Tried Googling, No Luck. Elvis folder in internal storage?
The .sph file starts off in text editor....
NIST_1A
1024
sample_count -i 83200
sample_rate -i 16000
sample_n_bytes -i 2
sample_byte_format -s2 01
channel_count -i 1
sample_coding -s3 pcm
end_head
If that helps anybody...
Or the .RPR (which I guess is gonna turn out to be for ok google now)
VstTextFile 1
FileType ElvisDump
FileVersion 3
ElvisVersion Elvis v19.0048.1 (depot #165174), Arm, Linux, gcc, Embedded Build
ElvisMajorVersion 48
ElvisMinorVersion 1
ElvisLanguage enus
RecogType Constraint
SampleRate 16000
RecogModelProperties 0
TTSModelProperties 0
VocMaxNumAddedWords 8000
LengthLMContext 1
LMContext[0] -1
LMContext UNKNOWN
RejectionScore 0
Confidence -1
FESnapshotSize 468
Same here. I could never figure out what the files are from.
I too just found this file folder this afternoon. Through opening the files with Note Pad, it looks like the folder and associated files have to do with the "Okay Google Now" voice command. I say this because there are numerous references in the program language referencing "speech" and "recognition". Hope this answers your question.
Chris 4502
