Epic detects USB when connected to wall charger
The times I've seen this behavior, it's usually that the end of the USB cable that's plugged into the wall plug isn't all the way in the plug. Try reseating it (this is at the power end, not the phone end).
@Awesomo4308 It's only a problem because I don't think it charges as fast via USB. This wouldnt be an issue, I guess, if I used my phone a bit less but I'm on it constantly playing Wordfeud with my family out-of-state and it drains the battery pretty fast. Also I'm on my phone quite a bit at work as well.
I had this happen a couple of times, all I did to fix it was reseat the usb cable on charger side and it went away.
Dgeeksldugen
