esr magsafe charger kickstand doing 15 watts at home instead using 45 watts charger with cords for super fast charge 2.0
y2jman
718
23
18
am i dumb to be using that
ESR HaloLock Qi2 for Magsafe Charger with Kickstand, 15W<-am not a fan of kickstand didn't know it was little i thought was a charger pad like s20 charging fast wireless stand with fan on it guess i was wrong​
i don't know if i can find me a charging pad like s20 plus my brother did mention about a dock/ charging stand but since phone had a magnet on it wanted to try that magsafe charger ya know
that my brother order off amazon for me to charge at home s25 plus i'm using a 45 watt charger and it has own cord does fast charge and wireless at home
or do you think i should just used 45 watts charger cable for it to be super fast charger 2.0 the ankle 45 watt charger i'm going to take with me when travel with cable
i guess because on s20 plus at home with charging pad i and it was a wall adopter at home i always do it does fast charge wireless then when travel i would had take that super fast charger wall adopter
it doesn't matter right if i used 45 watts charger at home with cables for super fast charge 2.0 or that magnetic charge thing and all i have to used 1 of the 45 watts charger connect it goes from fast charge to wireless charge eh
on a side note the easdmn 45 watts charger doesn't have word easmn
instead of what saying amazon
it actually saids this but i do still see it does super fast charger 2.0
I tried it too, sent it back next day. Not very convenient and the stand is useless.
Got a Qi2 charging stand for iPhone. Works great with S25U and charging Buds3 Pro with a case without a problem.
For travel I have 3-in-1 portable charger.
so you don't think that esr halo lock qi2 charger is worth? what do you recommend me doing at home then instead just doing 45 watts charger either anker or the easdrmn
i don't need 3 in 1 charger since don't have a samsung watch
you think i should stay away from any qui2 magsafe magnetc chargers like
i don't think i need a magsafe charger qui2 that makes phone cold like this
charger stands i see is this one
what do you recommend?
the
Qi2 Magsafe Compatible Wireless Charger Stand, Threekey Qi2-Certified 15W Detachable Design Magnetic Desk Charging Station​
what folks saying in reviews: Charges quickly, but not as fast as others. Extremely strong magnet and stable base holds my heavy Samsung S25 phone/case combo without tipping. The strength of the magnet makes holding the base while removing the phone necessary. The USB C charging port on the puck allows use of any compatible cable and the fact that the puck can be removed from the base, makes this one of the most versatile units available.
another one saying Product is great, never seen fast wireless charging appear on my Samsung s25 ultra until this device, even thogh this is a apple charger, the s25 ultra also has qi2 charging. The charging pucks is removable to allow charging of non magnetic devices flat on the base. The only reason this isn't 5 star is I was hoping both surfaces would be active at the same time and could charge 2 devices at a time. Still a solid product, and likely I just had higher hopes for dual charging with the single cable. It does come with a cradle for holding a seperate round charging puck. Maybe works for apple watch as what this device is listed for, but the cradle is too small for Samsung watch charger. That had 0 effect on my rating, I just think for the price should have dual charge capability. Still happy with the product.
The Holder 5 stars.
1) Very wide base that holds the phone well..
2) 180 movement from side to up to other side.
3) 2 places to place charger.
4) Lacks Horizontal movement.
The Charger Puck. 4 stars
1) 15w charger with slower speeds as compared to my 45w charger.
2) Seems to get pretty hot while in use with my s25s.
3) Wish it had a fan system with it but it wouldn't be as small.
4) Easy to take on and off and sticks well to the magnet on the phone and holder
Belkin Magnetic Foldable Wireless Charging Stand 15W - MagSafe-Compatible Qi2-Certified Charger, Wireless Charging Stand​
reviews are saying: perfect for s25<-that's not much of a review
umm 1st one
Compatible with MagSafe Charger, 15W MagSafe Charger Stand, 360°Rotation Base Adjustable Foldable Wireless Charger for Samsung Galaxy S25<-no reviews s25​
INIU for Magsafe Charger, 15W Fast Charging Magnetic Wireless Charger Stand, Travel Essential Wireless Charging Station with Sleep-Friendly Adaptive Light,​
1 review
I use this charger with an S25 Ultra and a mag-safe style case, and to put it simply - the charger works flawlessly. I use it every day as my main charger, and wouldn't hesitate to recommend it.
The charging stand itself is a nicely weighted metal base that holds your phone at a convenient angle - one where you can easily read & interact with the phone screen as needed. The magnets on the charger are strong, and "pull" the phone right into position - I use it daily, and have never had to reposition or adjust the phone to get a solid connection & good charge. Charging is as fast as you can get for the S25 Ultra (15 watts for wireless), and it charges at a rate that feels fine for a wireless system. The braided cable sleeve covering is also a nice "upgrade" to the usual basic charging cable.
When I first setup the charger, I was initially concerned that the charging "disc" might repeatedly shift or come loose from the base (as the phone is placed on the charger and removed), requiring repeated adjustments and similar to keep everything in position. Happily, that has proven not to be an issue. The charging disc stays reliably seated within the base, and in cases when it does shift when removing the phone - it pops itself back into position as soon as the phone is pulled completely away.
My only complaint about this charger is the fan noise. The fan does seem to be functional in terms of limiting heat build up, but in keeping it on my desk about 2 feet away - I can hear the air blowing through the fan when its charging. It's honestly not particularly loud at all, but enough that I'm aware of it when it's running. Ideally it wouldn't be necessary, but in fairness it seems like a small tradeoff in exchange for using the full 15 watts of charging power.
i guess i need one that can charge up like s20 plus charging thing that was on old phone that was like this with a cooling fan
samsung-fast-charge-wireless-charging-stand-black-ep-ng930tbuvzw-iset
now why i can't find something like that s25 plus on amazon i don't know
i can do an anker stand but don't know what to get of all the 4 stands that i put down the belkin is prob the best right?
slackingfred
