Evo 3D Software Update August 18
yeah, mine seems about the same, maybe slightly better....
always on mobile data, only gmail/facebook/tweetdeck syncing, live wallpaper, currently at 1 day 3 hours at about 12 percent left.
I've noticed speakerphone and earpiece volume is louder. My volume was so bad prior to the update, I downloaded Volume+ to increase call & speakerphone volume. It worked well. After the update, my call volume is noticeably louder. Had to turn volume down on a call. People I've called say I sound better.
I like the new screenshot too. Was very disappointed that Shoot Me wouldn't work on my 3D like it did on my 4G.
Noticed after deleting the email trash folder and I tap the back buttion, it doesn't automatically go back to the inbox screen. The back button now takes me to the home screen. Anyone else having the same issue?
Has anyone been having issues with Juice defender since the update? It does not appear to be working for me anymore.
I did notice the volume on both the ear piece and the speaker phone is louder.
Also...when I jump from lock screen to main...I get a sound that reminds me of a vacuum cleaner.
I tried to download the tip calculator from HTC Hub...it installs OK...but the widget isn't in the apps. When I uninstall it...it causes a reboot.
I have noticed a quite click sound when taking photos, not the louder shutter noise prior to the update.
Also, I don't know if this happened before, but the volume buttons zooms the camera in and out.
Yes the volume buttons do adjust Zoom level before the update.
I'm debating whether to update or hold off, since I roted. Partly I'm waiting to hear how well the GPS fix is. It does take a while to lock on. Not as dead on the spot as my Hero was. Most times indoors it'll show my location at the towers. Wouldn't mine it if it at least showed me somewhere with in the block while inside. Mine does throw off Google Navigation. Going down the Highway it'll jump me down on the city streets next to it and start spouting off directions to get out from there. Maybe a few of my pictures get a green tint. Haven't used it too much, Except for the 3D, which works quite well.
Paul
Paul
The GPS locks on immediately now.
I didn't notice this until today, but the Sprint Football Live app took a major update. I'm liking the way it looks too.
I am still having an issue with generic android icons for some of my apps, even after the update. Any suggestions for a fix?
Is the green tint issue in pictures gone now?
I didn't seem to have the problem to the extent that some people reported but I am not seeing it at all. I have also found that I don't need to change settings as often as previously, although I still change them in certain situations as suggested in your article. I saw a post here somewhere in which a person had the green tint before but after the update couldn't reproduce it.
The GPS seems way more accurate. Now it shows that I'm in my house when before the update it showed that I was on my driveway. (And yes both times I was inside of the house:p)
For those with battery drain issues try a power down and battery pull, that used to work on my 4G.
GPS for me is less accurate and it seems to lose GPS signal much easier now. I just used navigation on the way home yesterday and lost GPS signal multiple times.
App icons appear to be fixed for me.
Volume I think is louder.
No more taking pics of unsuspecting people for you! You must be one of the people of Walmart photographers! I'm glad they disabled it!
Sent from my PG86100 using Tapatalk
I think that is ridiculous! It should be an option, period. I want the option. I am an adult and can be responsible for my own actions.
knightrider85
