Extended Battery case
HOG#AC
7
Has anyone had any luck finding a suitable case for the Thunderbolt when it is equipped with the HTC 2750mAh Extended Battery? The battery holds up well, by the way.
Verizon sells the shell holster combo for the Tb. What you do is leave off the back cover and just slide the phone into on case that goes onto belt screen facing inwards. works absolutely great. I have been using it like that for 3 weeks now not any problem.
Me too! Works great!!
suuu
