Hi all,
I purchased the extended battery from a Verizon store yesterday (got the $25 deal, yay!) and whilst the battery itself seems fine so far, the battery door which comes with it doesn't seem to fit quite right.
The first door I got was slightly scratched on the left-hand (USB/HDMI) side of the phone (the rubber coating was slightly worn away) and on the right-hand side of the phone, below the volume buttons, it would never click quite right into place. Whilst I could make the door click into place, it would easily just pop out again. All the other "click points" on the phone were fine, the door was extremely snug everywhere else.
I returned the battery and door for a replacement, and the replacement door has no scratches on it, but on the right of the phone, in the same place as before, it still doesn't fit quite right. It is more snug than the previous door, and does click in further, however there's still a tiny amount of give - and a creak when I lightly push it there.
The standard battery door does not do this at all, it is perfectly snug all the way around the phone, so I don't think it's a problem with my phone.
Does anyone else have this problem? I'm just wondering if I'm very unlucky (or perhaps too picky) and if it's worth taking the battery and door for another replacement - or maybe all the extended battery doors are like this?
BTW it's also not an issue with the battery being improperly seated - the extended door behaves the same even with the standard battery - or no battery at all - installed in the phone.
Thanks in advance for your input!
Craig
Craig
