extended battery or battery pack
pnico
242
hi, im traveling over seas with my razor in a few weeks and knowing the battery is so so, does it pay to invest in a battery pack?
does anyone have one? if so, is it any good?
I was actually considering going back to the bionic, but I dont know if it will have the ICS upgrade.
any suggestions?
thank you
I have the Anker 5500 mH and I've been really happy with it. Not sure about recharging on 220 v though. You might contact the distributor.
I think your best bet is to get an adapter for your normal charger. There is no extended battery for the razr due to the non-removal battery. The Motorola P793 battery pack looks good, but even then, your gonna need to be able to charge it somehow...
I have the mophie 6000 battery pack and love it it has charged my razr 3 times and still had something left. Would be good focused on flights so you could watch movies. All you need for over seas is a universal charger.
Sent from my VTAB1008 using Android Central Forums
amaka
