Extended battery question
Yeap - but if you're going to go extended on the Rezound, you'll still need to purchase an extended battery for it so you have the appropriate cover to accommodate the larger size of the battery.
I'm using the extended battery from the Tbolt along with the new one in mine; no issues of any kind to worry about.
What size is the extended battery for the T-Bolt? Is it better than the one offered for the Rezound? I already have the extended battery cover.
It is the same, just that those who upgrade from the thunderbolt to the rezound can use the same extended battery. The stock thunderbolt battery won't work on the rezound.
Got the big boy HTC battery...already
Now I Am TRYING TO find extended OEM cover................... (w/o batt.)FOR SALE FOR MY Rezound.
Thats the real PIA !$
Get it on eBay...that's where I got mine.
Sent from my ADR6425LVW using Tapatalk 2
tomthedaddy209
