Extended OEM battery for GSII?
chestvrg
431
12
18
I'm interested to see if anyone knows of a manufacturer (such as SEIDIO) that makes an extended battery in same OEM size as the one that the Galaxy S II comes with, since I'm a heavy data usage user I'm sure I'm going to need more then just the 1650mAh that it ships with. I'm sure if there are none at the moment, eventually a manufacturer can bump up an extended batter to somewhere around 1800mAh while keeping the same OEM size.
Thank you for responding, do you happen to have the link where to buy that battery?
-- Sent from my Palm Pre using Forums
ladakh
