extra battery charger
tarnak
266
4
Is there a battery charger for extra batteries? i have not seen one listed yet. I do not think I would like an extended battery, but I would not mind having an extra standard battery on hand.
Thanks
Re: extra battery chargeer
do you mean a charging dock for only the battery? If so, I'm wondering about this too!
Also, does anyone know if a 3rd party battery charger or universal battery charger would be compatible with charging official htc rezound batteries?
i bought the htc thunderbolt external battery charger for $4 from verizon and it works fine on Rezound batteries.
I think that is exactly what I am looking for. Just something simple to charge the battery like we have for our Blackberry phones at work.
Thanks for the info
I didn't see the $4 charger from verizon, so if you can find that one go with that. I bought this one from Sedio. It's actually the one for the Thunderbolt, but it also works for the Rezound. The charging unit is a bit bigger than I wanted, but I figure when I get another phone I can just buy the adapter plate from Seido for the new phone/battery and be good to go.
seidioonline.com
The $4 battry charger on both the Verizon tb and Rezound accessories pages seems to have been replaced by a $22 one. Works fine but costs a lot more. They must have received some kind of a one time deal on the original batch of $4 units.
I have one and my blackberry charger and my generic car charger works just fine. Regular MicroUSB works perfectly fine on the Rezound
FYI So this UBOC Universal Battery Charger works great. www.UBOC411.com is the site. Fully adjustable interface. Chargers my extra battery. Cool Beans.
It's like 10 Bucks. Check it out!
Solder has been degraded by new material standards. More tin and less lead in solder material. That make solder joint connections more brittle. Anyway the UBOC Universal battery charger can charge your battery. eBay has them. One size fits all. Hope that helps! I know it has helped many people with this same problem.
cinemacritic
