Fab to work on Apex this Weekend
I'd like
curved lock bar
removed data throttling
gala x / s theme
working HDMI (not that i use it much, but if i need to it would be nice to have)
as much speed as one can get
toolbox
Making a Apex boot animation with sound. Almost done just working out timing. Hope its done when he's done.
Sent from my DROIDX using Tapatalk
Change the lock screen, some kind of widgetlocker type system. Or at least make it so the slider doesn't lag.
Motorolas player to be included in Apex. This player is to die for! Ok maybe a little excited there, but the just released leak will most likely be included in the next Apex.
But why wait.........try it, you might like it.
http://dl.dropbox.com/u/11232883/Android Central/Motorola_Music_Player_1.0.179.apk
No not the blur,
Original post edited.
I wonder if it will index new files right away when I add new ones to my sd card, unlike the current one. Am I alone with that problem? I have to reboot to get them to show up.
Toolbox, rotary unlock, keep overclock script, possibly some screen transition options. I can't remember if apeX had the double tap home button for a shortcut or not. Toss that on please. Themeing as well would be Awesomesauce. I think that's what I like the most about Liberty. I don't like the stock look or feel at all. ApeX is awesome but I'm not into the gingerbread framework and menus. Here's one more item. Fission had a blackout theme. That would be very niiice on apeX.
Sign me up for these changes.
Could be just me, but looking into the software bug of how it reports the phone signal would be excellent.
With the Motorola firmware the signal stayed strong at 3-4 bars, but on ApeX, the signal tends to show only 1 bar, and then erratically jump about. I checked the signal strength while it was doing it, and it should be a 3-4 bar report all the time. But I catch it every time starting off with 1 bar from idle, and then it acts like "Oh snap, he's back, time to play games with his mind."
I have the battery mode set to performance, so it shouldn't be acting like it's conserving energy.
Thanks Fab!
anyword on when this newer version of apex is coming? i am getting anxious!!! this thread was created almost 2 weeks ago...
edit... just got this reply in droidforums.net
"A few days ago I posted that on Twitter he said on the 21st that he was going to "start work on an ApeX update tomorrow."
He has been talking of the new leaked Motorola music player a lot, and says it's awesome. I'm looking for that and then a few more Gingerbread features (courtesy of the new 3.0 SDK) "
__________________
__________________
New music player is awesome. Honeycomb is 3.0 so when the full file drops hope some is in.
mnundy1
