Facebook crashing...
It started to happen to me since last Tuesday.
My husbands phone hasn't had Facebook work on it since about tuesday. overtime he tries to get on, it starts to load then comes up Facebook has stopped working. we've uninstalled and reinstalled, reset his entire phone and still won't work. yes works perfectly fine on my note 4.
Yes my GS6 now works with the beta programme, it only stopped working 2 or 3 days ago.
None of the options worked for me. but I found another solution. When login to Facebook, skip the option of automatic log in. ( I think it is called one tap log in). Once skipped, everything works normal again.
Well I just installed the facebook lite instead, well it's not as good as the features in the newest version of a facebook app, but atleast i can still use facebook. without crashing. which do you prefer, a cheap facebook or no facebook at all?
go on, just try it. Facebook Lite, the logo is in reverse color, white is the backgraound and the f is color blue
had the same issue after updating my fb app.
here's how I solved my problem:
- uninstall facebook.
- update your phone software (setting / about / software update)
- reinstall facebook
- walla - works !
good luck.
Mine did the same (galaxy s6) so I uninstalled the facebook app and the facebook messenger and now when I go to the app store to reinstall it says that facebook is not compatible with this device....sigh, how fun is this!
easy step :
1. go to Setting
2. go to Application Manager
3. find Facebook on Downloaded Tab
4. Click CLEAR DATA
5. Close Setting
6. Open FB & enjoy it.
Thanks.
I have applied the fix but this is still happening. Only started today
Also it starred happening after an update. I have also deleted and reinstalled the app but it is still happening
I've been having exactly the same issue since the update this AM (UK). Cleared all data, uninstalled, reinstalled and the problem persists. To be honest, it's been a breath of fresh air spending less time on it! Unfortunately a lot of friends and family are abroad and it's the easiest / laziest way to keep in touch so could do with a fix... Sharpish ☺
it maybe a temporary fix downloading an older version from ApkMirror and select "don't auto-update apps" in the Play Store settings :)
Google: Android Facebook Beta Program, sorry can't post links, stupid account rules... Once you find the page on Google groups, make sure your not joined as a beta user, if so leave the program.
Uninstall Facebook
Wait 30 mins, reinstall
Doing so should drop you from the problem build of 37.0.0.1.234 to the working build of 36.0.0.39.166
This is working!
Hey guys , thus is Anupam from India . Solution :
1 . Open Facebook
2 . Open App settings (help & setting)
3 . Autoplay
4 . Set it to never autoplay video
That's it , thanks .
I stopped using the Facebook app and started using the browser version. It's a billion times better and saves battery.
Yeah, for my mother who has an LG G Pro 2 on 5.0.1, THE BROWSER VERSION IS NOT AN OPTION AT. ALL. My mother's very pissed at me because she said the website's TOO SLOW, sharing and liking stuff is almost impossible, and uploading stuff? Not gonna happen!
I don't have a problem with those compromises but she DOESN'T, so if anyone has a better solution I BEG OF YOU TO SHARE IT. :(
This morning i recieved an update from google play since then every time i go on facebook it either crashes back to blue screen or my homescreen
gianfranco
