Facebook Notification Sound
Had this problem as well. Dpw09 has the right protocol for those who have new FB versions. Why it is hidden there I don't know, but it does work to change FB ringtones.
same idea as dpw. Just as good.should have given you credit for the help as well. thanks!
FACEBOOK NOTIFICATIONS FIX>> log into facebook DESKTOP >> click on the GLOBE NOTIFICATION ICON >> click on MARK ALL READ >> then your notifications will work again you might have to do this from time to time depending how you clear your notifications,,>> NO NEED TO REINSTALL APP as others suggest,,,,,reason why it stops is because notifications box gets full from not reading all alerts
Go back into notification settings and scroll to the bottom of the page where it shows "Where you receive notification" options. Select "Push". Option to change sound is in there on the latest android version
New version: go into Notification Settings. Scroll down to "Where you receive them" list. Select "push" option. Select "tones" and change tone
go back into notification settings and scroll to the bottom of the page where it shows "where you receive notification" options. Select "push". Option to change sound is in there on the latest android version
that's it!!!!! Thx so much <3 <3 <3 <3 <3 <3
salahpin
