factory reset please help me !!!!!
  • Start date Start date
A
AC Question
today i factory reset my phone and i have this message cps has stopped and after that nothing work !!!! please help me !!!!!
Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-10853
If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
So you're saying that you still get the same error messages in Safe Mode? Then it's more likely to be a corrupt firmware, or perhaps a motherboard problem. I'm not sure what else you can do from that standpoint. The last thing I can suggest is to remove the SD card, if one is inserted, since a corrupt card can cause various issues.
KidColoringPage
