Fascinate on Page Plus no mms Need Help
Tomm2222
4
I switched from Verizon to Page Plus.
Can receive text but no pics.I have reset phone and tried *22890 no luck. i have spent hours looking for a fix. Any help would be GREATLY appreciated ps I do have data.
Thanks
:-$ Tom
Hardware I500.04
Firmware 2.2.2
Baseband Si500.04V.ed05
Kernel 2.6.32.9
Build SCH-I500.ed05
Not sure, but how is the service reliability with Page Plus? Fast internet? How did you switch it, did they flash it? Because I was thinking of switch to MyCricket but not sure ! $55 for unlimited data, text, 1000 minutes.
Service is great, do you have the messaging turned off in settings mine works fine? also just activate on PPC no flashing needed.
Also do a *22891 that may help. They have a unlimited talk and text with 300 meg data for $55.00 just came out with it.
found this also. Easy fix. In Messaging, go to Settings. Under MMS, uncheck Auto-retrieve.
No need to uninstall apps or install new ones.
You just need to click "download" when you get an MMS message.
Hey Thanks
I tried the *22891 no luck. Then unchecked Auto-retrieve.still no luck.Any other ideas?
try *228, then My next suggestion is do a factory restore and that reprograms the phone to new. I don't have a problem with mine. i will keep checking some other forums and see what i can find.
And why?
Verizon allows this phone to be prepaid. So why not use them as prepaid?
I know its more money, but its good though.
I downloaded go sms pro from market instead of the default works part time with a link to picture. is there sometinhg
Ican set it mms seetings
Thanks for all the help Guys!
Tom
Welcome, I don't understand why it did not work stock, mine does. Also searching shows that it seems to be a ongoing thing with some phones.
I just activated my Fascinate (running ICS) on Page Plus! Everything works just fine--I don't know why it would matter if I'm running an AOSP rom or not.
we flash our used to be us cellular samsung galaxy s 2 over to page plus... cant get the internet to work not sure why?? :/
santmarrys
