A
Android Central Question
My phone is about a year old and I thought previously that the charging port was damaged and now I'm pretty sure it is. The first time I had a lot of dust in the port and it would barely cable charge at all. Got it cleaned up then it worked fine for a bit. Fast wireless charging works fine so I'm lead to believe it isn't a battery issue. The fast charging is enabled on the phone before anyone suggests that. The cable is in the phone and charger securely. It will say fast charging for just a few seconds depending on how I put the cable in and only seems to work on one particular side of the USB C cable. Then it will act like I unplugged and plugged back in really fast and say cable charging. So does anyone have a suggestion besides going to the store other than what Ive already listed?? Thanks
