Fast charge, wireless, portable charger
ihbsbA
1,417
5
Is this a thing?
Wireless
Fast charge capable
Portable
I've been out of the wireless charging game for a while..
I don't have a specific suggestion, but some of the flat wireless chargers may be small enough to be considered portable.
Another option may be a battery powered wireless charger.
The most portable option will still likely be a wired charger. I'm usually charging multiple devices when I travel so I use an Anker 5 port charger that has one quick charge port. But I'm usually traveling with someone and this allows her not to have to bring chargers either or I'm traveling for work, which may require me to charge some tablets so it works pretty well. I doubt I'll ever bring a wireless charger in addition to it. Just too much clutter.
I meant portable as in a battery pack - not needing AC, ������ - so, you know, when I'm in the middle of the woods, I can charge my phone... hehe ������������
You can find a few on Amazon but I don't think they offer fast wireless charging and I'm not sure as to which one is a quality one. You'll have to read the reviews on them.
That's what I've been doing. Mixed reviews..some say yes, some say no...some people are just dumb. Lol
I'd probably recommend just a standard quick charge battery pack from Anker. They make quality products and are fairly priced. The ones that have wireless charging you'll need to keep stationary as the wireless charging needs a steady connection. With a regular one you can just connect it to your phone and throw it in your backpack or pocket.
oval_clarity
