fast wireless charging
wezzyd
270
Hi guys. Are the fast wireless chargers compatible with the s6?
Regular s6 and s6 edge is not compatible with the fast part of a fast wireless charger. They will charge at the regular rate. Unless something has changed since I looked last.
Just says charging wirelessly when I put it on the fast wireless charger. But it does seem to charge faster than typical wireless charging so I don't know
Just thought with the s6 supporting the same fast charging as the s7, it would work
Found an article on android central and the s6 does support the fast wireless chargers
Fast charging through the outlet yes on both. Fast charging on my s6 with wireless fast charge no. Unless the marshmallow update enabled wireless fast charging. I'm still on version 5 so I can't speak on that.
Only the edge plus variant supports fast wireless charging.
The charging rate is determined by the hardware, not software.
As noted above, the S6 Edge+ and Note 5 were the first models to support wireless fast charging. The regular S6/S6 Edge only support wired fast charging.
LilPandaBear1105
