Faster battery drain after Dec 5th update
  • Start date Start date
A
Android Central Question
Since the Dec 5th update I have noticed that my Pixel 3 drops about 12% in the 8 hrs, compared to about 8% prior to updating, while I sleep and the phone is in stand by mode.
I have adaptive battery on and dark mode on. I do have always on display on as I use it as my clock.
Anybody else notice this and any input on how else I may minimize it? Thanks.
One of the fix in December update is tune down the agressiveness of the memory management so that some apps can stay running in the background. Of course, that will add extra battery drain if you happen to have those apps installed.
It you close the apps (Back button) instead of leaving hem all running (Home button), Android manages battery a lot better.
From the reports I am seeing on Reddit most are seeing better performance -- nothing much of battery life there.
No change here either. I have seen the improvement on the RAM side though, opening Snapchat doesnt take a year or crash anymore.
Out of curiosity, because it happens with my past Samsung phones that I've had in the past and thought it would be different with the Pixel, but does your battery, after being charged overnight, go from 100% down to 97% in about 2-3 minutes after being unplugged and using it? By the time I go out of the door to go to work, I am usually at 93%. Is this normal?
Yes! Those first few percentage points go quick and then the battery drops more or less linearly. It's weird. Different from my old phones (iPhones).
Ah ok. Yes, that is what I've been noticing. Drop quickly, then drops less as hours go by. I assumed it was just a Samsung thing, but I guess it's an android because I never had that problem with my iphone a few years back.
Thanks for your reply.
Happens with all my andriod but 93% usually after phone been around 2 hours after fully charged and 1 hour sot
I've had the same problem on my 3XL, seemingly worse, though. Since the update, I drop ~7% an hour with just moderate use. I don't know what it was before, but certainly nothing even approaching that kind of drain. I have adaptive battery on, and the phone reports "apps are running normally / phone has typical background battery usage."
I was hoping the phone would "settle" after the update, but that doesn't appear to be happening. Normally, if I have a battery drain problem after an update, I'll factory reset the phone. But this phone is less than two months old! I don't suppose I have any other choice though. :(
But doesn't the last few percentages take forever to fully charge, so shouldn't the phone last awhile at 100%? I've been noticing this in my Pixel 3 XL too.
Yep, keep those updates coming Google. I don't think the closing background apps issue has been 100% fixed either. I had my music player app (Rocket player) closed down by the system recently and it was the only app I was running at the time!
Was it running in the background or did it should down while you were using it?
If it was the only app running and it shut down it might be an app issue.
The reason I though so was the app itself warned me the system was shutting it down, and I needed to change certain settings from preventing that from happening again. So the problem seemed to be coming from the OS.
mostafamu
