Feb '19 updates
Two month in a row where the OTA went out at around the same time as the images for T-Mobile. If March is this quick, we might have a new pattern.
Yep, OTA out on day one. No need to side load any more. Just hit check for update and voila! So easy, a cave man can do it.
Anyone noticed that About Phone is now out at the Setting menu vs under System?
The notch setting has a new option "tall cutout". All it seem to do is give you an extra notification icon on the left
The notch settings but from what I'm reading that was already an option.
The one in developer settings though not in settings?
Edit: Nevermind
Your still talking about developer settings I thought Google put in settings haven't played with phone much after updating.
I'm still stuck on the December update. I'm using Google fi and an unlocked bootloader. Not rooted. Not sure why I'm not getting security updates? Thoughts?
Try restarting the device see if it picks it up .
I have a Pixel 3. I noticed from previous posts that the February update is out. I haven't been notified that the February update is available. When will I receive the new notification. Thank you
Re: February 2019
You can go in and manually request the update.
Settings>System>System Update>Check for update.
Re: February 2019
Like Rukbat mentioned its staged roll out or try sideload it if your familiar.
Sometimes I turn my device off for a minute turn it back on refresh everything could get it that way otherwise have to wait . Now if it takes over a week and nothing then I would be concerned.
Re: February 2019
I still don't have the update but I'll take your advice and wait a few more days before I go into aggravation increases. Thanks for the suggestion
Re: February 2019
Have you tried to manually check for the update?
Re: February 2019
Still waiting here as well.
Roll out has been fairly inconsistent for me over the past few month.
Re: February 2019
Nothing to get aggravated about. As long as you get it within the release week you're fine. I couldnt imagine how you would feel with a Samsung phone not knowing when, if ever, you would get updates.
Winnie
