Firmware not updating on samsung note9
  • Start date Start date
I have done it. Still didn't install.... thanks alot for your help
No problem, go to settings >apps> tap the 3 dots upper right corner >scroll to system apps and look for software update app should be 2 of them next to each other , want you tap each of them clear data, cache, force stop and try to update afterwards.
It's still the same. It won't install ..... it just freezes when its installing the system update after it has downloaded, and says "error", then it shows "failed to update firmware. Visit Samsung service center"
Oh wow....then 2 options flash through Odin or do a factory reset and see if that works.
Make sure your on good wifi also.
kyw
