Firmware Update 5/16/2012
Has anyone experienced a battery drop off after the install? I have a full charge on my tablet and dock with no issues with reboots...yet. But i have noticed that when the battery level gets to around 45% left it tanks to zero. In looking at the pretty battery graph it looks like a cliff. It then will take time to charge it back up again. Anyone else seeing this? Thanks.
It appears like the rr's and sod issues are fixed with. 24, but the functionality of the core Google apps are awful.. Especially gmail and maps. Can hardly use Gmail without starting with a fresh reboot
Where do i find this battery graph?
Settings > Battery. Below where it says how long you have been off charging there is a small graph. Click on it and it expands.
I haven't been seeing a problem on battery life. I had my tablet running Pandora from 7 am till 4 pm and used it a lot in the evening and only went through 1/2 of my dock battery. Doesn't seem that bad to me.
Sent from my Transformer TF101 using Android Central Forums
I recently bought a used tf101 and was concerned about ICS performance after reading through this thread. I am glad to report that my tablet has been running flawlessly on the current version of ICS. When I bought the tablet the first thing I did was check for updates and then I did a factory reset, just to be safe. I have not had a single app freeze, system reboot or sleep of death, and I use my tablet a lot.
I also picked up a used docking keyboard and it is functioning properly as well. I am loving this tablet!!
jackgomes0321
