Just wanted to post an awesome and very quick fix for upgrading to Froyo 2.2 for a user with Unrevoked3... YOU WILL LOSE ROOT HOWEVER.
Posted from another forum- lonlawrence "Totally works. 1. download the froyo update 2. change name to "update" (without quotes). Change only the name. Leave the "zip" extension alone! 3. take out your evo battery and remove your SD card. Put it in your computer and drag the new file to it (or hook your phone to the computer via usb cable and drag the new file to SD card). 4. replace card (if you removed it) and battery and re-start phone (see 5) 5. hold the "up volume" button while starting the phone. 6. navigate to "bootloader" with up/down volume buttons (mine was already sitting on "bootloader") and select with power button. 7. find and select "recovery" (again with the power button). Phone will boot into recover mode. 8. select "apply update.zip" (again with the power button). That's it. It will take your phone about 5-10 minutes to completely recover. Don't worry about the box with a green arrow coming out of it pointing to a little android guy. That's part of the process. When it's all done, you will have Froyo 2.2, you didn't wipe or lose anything (except root), but Superuser permissions app will still be in your apps."
