Flash 10.2 on XOOM available right now!!!!!
Did anyone else's flash install mess up youtube app? Myvideos are in single file instead of the default view now.
This is working pretty well for a pre beta. Just watched 20 min of soccer on espn3. Was one level below premium HD quality.
Watched some TV shows on Fox.com and it worked well, video and audio were pretty much flawless. I tried Hulu and got a message saying my device isn't supported. Has anyone gotten Hulu to work?
That should work i think he just did a hex edit on the flash player to make it seem as if its a computer not an android device. The same mod works on phones as well. A better layout to view hulu with the modded flash is Hulu Player Widget
please let me know if this works, if it does ill update OP with the link to the modded version as well.
This is great, I just watched 30 minutes of a move from Amozon Prime instant video with my Zoom connected to a big screen TV via HDMI.
I tried the Hulu fix file and it seems to have broken flash. My system no longer recognises that flash is installed.
did u uninstall the old version before installing the fix? also i think u need to use stock browser and do about:debug and put UA to desktop
Yes, I uninstalled the old version. I also tried to set to UA. But can no longer find the option. Did it go away with the update? I uninstalled the Hulu version and reinstalled the original and it works again. .
I hope this isn't off topic, but I'm interested in getting a Xoom, but not being able to use Prezi for presentations is a deal breaker for me. There is an app for the iPad, but being able to use Prezi's flash based interface offering the ability to edit, and present with it would mean definitely buying the Xoom Wi Fi. Can one of you kind Xoom owning soles give Prezi.com a try? I am interested to find out how it works for you.
Not to hijack, but when I use the about debug and leave it in debug mode it leaves a JavaScript console banner across the top of the screen. How do you guys get rid of this while staying in debug mode-so that the browser is always identified as desktop?
shaik
