flash light
I do not have a torch in qslide or clean master app. Can anyone help me find it?
The clean master flashlight is in the widget in the notification pull down. I
I do not have this???
I do have an ATT update waiting so maybe after that????
Go in to clean master, swipe from the left of the screen to get to settings, the notification toggle is on the top. Switch it on.
bump. There is no flashlight on qslide. Do I have to be rooted to find it? Thanks
Apparently the ATT G3 has flashlight on qslide. T-Mobile - which I have - does not have flashlight on qslide. What carrier to you have?
I finally just downloaded Nexus Light for my wife's G3
Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
I also have quick torch from the quick circle apps which is nice to start from the circle. But before I had my circle case I had qtorch from the app store. It nicely integrated to the q slide and turned on and off with a slide button feel.
I have Verizon. No flashlight in QSlide on my G3. I believe my G2 had a flashlight in the widgets.
I think you just need to download qtorch from the play store then add it with the edit function on q slide.
heritagevines34
